Flicker
- Washington
I have an apartment building that has 100 amp duel pole Zinsco breakers in an electrical room that feed each apartment.
Over the years several of the Zinsco breakers have shown that they have worn out and I have replaced them. I have not had any wear out for several years now.
All of the current Zinsco breakers seem to be operating properly (not getting hot, no arcing noises, and not tripping).
I am considering replacing the Zinsco breakers with the Connecticut Electric UL listed breakers that are a like for like swap designed to replace the Zinsco breakers. This is because I worry that some of the Zinsco breakers are no longer functioning properly and may not trip even though the load is exceeding what they are rated for.
But the replacement breakers are expensive ($75-$100 each) and the swapping out cost would really add up.
I know worn breakers sometimes do not trip when supposed to but I am told it is much more likely that they will trip prematurely rather than not trip. What has been your experience?
Thanks.
Thanks.
