Hello all! Just have a quick question to run by you all. I'm bidding a job running power to a dock. I've looked through the code book and searched a few other avenues and haven't been able to find much info on it. I'm wondering if the feeder going to the dock (50 amp) needs to be GFI protected.
My biggest problem is if it does need to be, the feeder is @ 200 ft long and I'm afraid of the distance tripping the GFI breaker. The feeder will run from the house, down the yard to the dock and @ 20' under the dock (not in water, just piped on the underside) before it reaches its OCPD. I think I'm OK without GFI protection, but wanted to run it by some others first.
