360Youth
- Newport, NC
We are dealing with a floor heater cable issue right now. We installed the cable on a bathroom sub-floor in September (new home) so the tile guy could do his pour. I tested the system before we left and went my way. He called me the other day worried over a few spots where the cable had floated to the surface and asked that we do a check before he lays his tiles. Now the built-in GFCI on the thermostat trips immediately. After talking to factory and dealer reps the conclusion is there is a damaged cable. My mistake is not properly documenting that it worked. GC is not questioning that I tested before I left, but a smart man would have made sure before leaving and turning over to someone else. Any number things could have happened in the day or two between install and pour. If you are not in the habbit of documenting such things, please do so. I will try and be better about it, that is for sure.
