LadyDi
- Lubbock, Texas
- Electrical Contractor, Master Electrician, BA Texas Tech University, College Instructor: Electrician Education
Hello~
Does a 480/277 volt main disconnect need a neutral run with the ungrounded conductors for ground fault protection?
Note: The disconnect in question contains a black wire run with the ungrounded wires that is marked with green tape. The conductor is attached to the service bonding locknut, and then it is attached to the metal case. I believe the conductor serves as the equipment grounding conductor.
After considering the bonding and grounding DVD's, I believe that the service needs a neutral. Am I thinking correctly? If answered, then I'll share the results with my electrical students.
