Hi All,
if there is a small dip in the utility (I am talking 2 volts in 1-2 seconds) voltage would this affect the secondary voltage and by how much? I give you an example, I have a 600V system feeding a UPS and the UPS has a step down transformer within it that gives our 480V. the tolerance of the UPS is plus/minus 10% (not that this matter for the question but as an FYI). I reviewed the voltage on my Eaton meter and saw from the graph that a 2 volts drop in Phase B as Phase A-B and B-C dropped but not A-C so I assumed phase B was the issue (hope that is right). Then the UPS went to battery back up, this is a 150kVA UPS with the step down transformer in it, so before I figure out with the UPS manufacturer in regards to the tolerance level I wanted to confirm if the small dip in voltage affects it or does that small dip turn into losses and makes no difference in the secondary.
hope this makes sense as I am not good with explaining things.
Thanks,
Thanks,
