markjkubicki
- New York City
this is about a plug-in <somewhat decorative> lighting fixture:
the query is: "...the fixture is (European) CE approved; can it be 'legally' installed in the US?"
Previously, there would have been a few immediately disqualifying issues: voltage/Hz, plug configuration, lamp holder (socket), <etc.>
However, with the arrival of the LED, none of them are relevant:
- the power supply unit (PSU/driver) has an input voltage of 120-250V (ENEC), frequency 50-60HZ
- there is no lamp holder
- the plug can easily be "adapted"
- <etc.>
so the question is:
Does an internationally (?) recognized agency fall within the range of a nationally recognized agency ?
___________________________________
one other curious (somewhat parallel) note:
almost without exception today, our fixture specs call for fixture ratings not as "damp" or "wet", but under the far more specific European IP rating system:
EX
IPx3 = Water falling as a spray at any angle up to 60° from the vertical shall have no harmful effect
vs
IPx5 = Water projected by a nozzle (6.3mm) against enclosure from any direction shall have no harmful effects.
vs
IPx7 = Ingress of water in harmful quantity shall not be possible when the enclosure is immersed in water under defined conditions of pressure and time (up to 1 m of submersion).
and so forth
for the most part, we presume the implication of a "damp" or "wet" rating, overlay-ed with the additional criteria
- <etc.>
so the question is:
EX
vs
vs
and so forth
