als45
- Batesville, AR, USA
I am working on a zero turn lawnmower factory assembly area design. They also have a "Running Inspection" area. The mowers are assembled, gasoline is put in the tank from a portable gas can, and the mowers are ran for inspections. There is also a service area for the mowers. My question is does Article 511 apply to this building? They will do minor repairs in the service area. They are pouring gas into the tanks in the inspection area. However, transferring gas from a small gas can to a small tank does not seem to be the same risk as draining a automobile fuel tank into an open pan. Thanks for your help and opinions!
