Eddy Current
Where in the NEC does it mention drains and what the regulations for using them are?
Are you referring to the practice of using a vertically mounted Tee at the bottom of a run of RMC to drain the pipe?
If so, NEC doesn't care one way or another. But I've worked for facilities where they are required at the lowest point(s) of the conduits.
"Arranged to drain" appears several times.
Yeah that's the kind i was talking about, so no code for them?
Not trying to be a smarty pants, but where else do they think you are going to put them?
