goldstar
- New Jersey
- Electrical Contractor
The above is an excerpt from my post regarding the theft of electricity. As indicated there is a main (fused) disconnect ahead of all meters in this commercial building. 100 amp breaker panels ( that soon will be metered) that are currently installed downstream of this disconnect switch are all main lug panels. Once the metering problem is corrected (in your opinion) will these panels have to be converted to main breaker panels or will the main disconnect be considered an acceptable disconnect means for all panels ? Thanks in advance.The building is supplied with a 400 amp, 120/208, 3-phase service. The service enters the building into a disconnect switch and then down into a trough where it feeds 3 CT cabinets (the trough is a standard screw cover trough with no means of locking). The first cabinet has a demand rate meter and the other two don't. As far as I can tell it appears that the first occupants were metered and the other two CT cabinets were provided in anticipation of new tenants. Over the years, whoever the electrical contractors were provided power for the new tenants and set up their equipment in sections provided above the two spare CT cabinets.
Phil,
Gold Star Electric
