jischr
- St. Louis, MO, USA
We have equipment on the floor that has a 120V heater control circuit switch. When thrown the switch starts a screw motor in the MCC bucket to retract the blades and isolate the 480V circuit thereby allowing work on the equipment (not the 480V circuit). An indicator light changes color when the process is complete. I'm not sure if it is fed from the 480V system or a contact from the screw system. For the sake of this discussion let's presume the 480V switch can not be manually closed in the MCC room when the screw motor has retracted the blades. The MCC is located on a different floor of the buiding and not 'convienient' to access. The current practice is to lockout the 120V control circuit switch at the machine.
The question is, does this meet 1910.147 requirements of energy isolation. My view is no it does not because the 120V switch is not an energy isolation device for the 480V circuit. Others state it provides equivalent protection.
Thoughts? Comments?
Thoughts? Comments?
