Does anyone know if breaker-panel manufacturers are making the removal & re-install of front covers for maintenance and tests easier to do?
The last employer I had required 3-year checks on all wire connections (breakers/lugs,ect) in panels,transformers and disconnect switches.
Some of the panels were old and it was hard to put the covers back on and even some newer ones were a problem. My present employer has me testing ground resistance and ground leakage currents inside each panel, a yearly thing for the last few years.
Anyhow, I'm thinking if panel covers had hinges on one side and clips on the other it would be a big improvement.
Also, as far as ground resistance and leakage current, if there were built-in meters on the front of the panel, or if they were installed as a permanent set-up, with current transformers,or the appropriate coil that would do the job around the earth cable and another around the live and neutral conductors, it would save a lot of time and effort and soon pay for itself...
I think I'll suggest that one to the powers that be,actually...
