brother
Well i took a chance a bought a 'cheap' 24 hr timer from home 'cheapo'. I had the wireing already to go. This was the 'new and improve' model clerk told me will replace the switch and turn on appliances and other things anytime you want. .
So i buy and take it home open it up and just see the 2 wires. Hmmm, I thought these needed a neutral to work, (or some of the others that use a ground thats against code but thats another arguement).
I say oh well, its been a while since i put these in, maybe they come up with a different way for the 'return' complete circuit in these electronic timers. so i hook it up per the manufactures instructions. Well Because of the way i got this stuff wired it wont work with my fan/light and if the bulb blow or fan is unpluged for any reason.You have to reprogrammed the blasted thing cause when it looses power cause it looses its circuit.
It uses the 'load' as its return (neutral). If there is an open then it resets. ARRGH!! Just had to vent, this a bad design and i just dont understand why the manufacturers get away with such nonsense just to make a buck!! I had a neutral in the box but these new timers dont even have a spot to hook it up to one. Even the 'ground' models are not too bad compared to this. Ok im done. just a pet peve i wanted to get off my chest.
