goldstar
- New Jersey
- Electrical Contractor
Just thought we could all use a laugh to rid us from the winter dulldrums. I find it hard to believe neither the township or POCO has picked up on this and had the property owner make corrections
I've been stopping for coffee at this convenience store for years and just never got around to taking photos. As far as I can tell this has been this way for at least 15 years. In the first photo you'll notice that the siding guys removed all the SE straps, never put them back on and sided around the meter enclosure (typical in my area for some reason) and yes, if you can see that close there's a lock on the meter cover. Does the POCO really think someone is going to steel electricity
Meter enclosure
The next two photos show the SE cable leaving the house side of the meter and laying on the ground and then back up into the house along with the whip from the AC condenser unit. Yes, there's also a gas meter between both these points.
SE cable on ground
AC whip and entry to house
Now picture this (possible) scenario, a car is pulling into the convenience store parking lot, in the middle of the winter, with ice on the ground (like it is right now) and the driver's foot slips off the brake and inadvertently hits the gas pedal, jumps over the small concrete stop, hits the side of the house right where the gas meter is and where the SE cable is laying on the ground. Natural gas starts spewing out of the gas line, the crash cuts into the SE cable and ignites the natural gas and the rest would be history. I guess the only thing that could be worse would be if the condenser unit was also hit and freon was allowed to escape and deplete the ozone layer.
From the standpoint of workmanship my thinking is 1) Why would an electrician locate the meter so far away from the entry to the house and the breaker panel ?; 2) Why wasn't it installed in rigid gal-pipe for protection and 3) Why isn't there a protective barrier between the convenience store parking lot and this property ?
Based on how long this has been this way I guess we'll never know.
Meter enclosure
SE cable on ground
