In the olden days, before addressable systems, & depending on the manufacturer,
you could do that. You would've needed to use a relay listed for use with that particular FACP. These days, I don't know, but the tech support folks for the brand of system you are working on would.
Personally, I would encourage you to think ahead. Follow nhfire77's lead; extend the addressable loop & use an addressable relay. This method allows you to disable the mag door lock function (either manually at the keypad or via programming) during system testing, increasing the building's security.
