Double Breaker relays for main and transfer bus
mbrooke
Batteries Included
United States
Technician
Ok, so after much discussion (and recommendation) on another forum I've decided to use double breaker relays (SEL-411L for example) for the control of a main and transfer buss bar. Breaker 1 CT/VT/trip coil will control the normal breaker while Breaker 2 CT/VT/trip coil will control the transfer bus breaker. The transfer buss CT will go rack to rack and run through each relay's Breaker 2 terminal. One of the spare user interface buttons will be programed to ignore Breaker 2 CT's inputs unless depressed and enabled.
Is this easy to do? Has anyone done this before or have any concerns? Just double checking.
