mshields
- Boston, MA
Is it permisseable to combine two GFI's in one double duplex configuration?
mshields said:And yes that occured to me. So long as you put them in the same box, you'd only need the upstream device to be GFI.
The reason I asked was that a colleague told me he didn't think you could make a double duplex with GFI's. It occured to me that maybe there was some heating issue I was unaware of.
In any event, thanks for the input.
Mike
mdshunk said:I do it on a regular basis for whirlpool tubs with heat. Pump motor on one GFCI, and heat pack on the other GFCI, both in the same box.
How do you mean? A cover plate fits just fine. I always use a pretty deep box for dimmers and GFCI's when I remember. In the case of whirlpools with heat, I like to use a 2-1/8 deep four square with an RS cover, fixed under the mechanical space of the tub area. I normally feed that box with a 12/3chris kennedy said:Must be a real joy to trim that out.
I struggled with wether or not I wanted to use that installation method for some time, but I never did it that way. Reason being, if the GFCI trips, I'd rather the tub get some professional attention and testing rather than the occupant simply resetting the very convenient GFCI.georgestolz said:Typically, we'd hide the GFCI itself in a nearby closet or something, where the GFCI could be reset without getting under the tub.
You know, at some point somebody's gonna call you to remove that padlock from the access door to the underside of their tub, whether the GFCI trips or not - it clashes with the curtains.I'd rather the tub get some professional attention and testing rather than the occupant simply resetting the very convenient GFCI.
:grin:georgestolz said:You know, at some point somebody's gonna call you to remove that padlock from the access door to the underside of their tub, whether the GFCI trips or not - it clashes with the curtains.
