dlmerchant
- Windham, NH
Hello guys - I have a customer that would like to have a double duplex receptacle installed. One side of the receptacle would be a 120v 20a feed from a UPS power distribution panel. The other side would be a 240v 20a single phase (6-20R) feed from a utility-fed sub panel. Is it ok for these two circuits to share a common outlet box without isolation? Following that same thought, should be grounds be bonded? Thanks guys!
