If you have a two double ended switchgear with two tie breakers, each fed from a utility transformer (480/277- Secondary). The tie in conductors between the gears have neutral and ground conductors. I was told by the contractor the bonding of the neutral and ground should only happen at one of the switchgear not both. Is this true? I always bond them at the first disconnecting means which in this case each gear. Any thoughts? thanks,
