Double-Tapped Neutrals - where to put them ???
DallasDave
New User
Dallas Texas
Retired
In my Challenger service panel (no shutoff before it), the neutral bar and the ground bar are bonded under a plastic cover piece behind the main shutoff.
Electrical wiring Circuit Component Electrical cable Technology Electrical Supply
The ground bar allows for double-tapped EGCs.
Font Number
I have 5 double-tapped neutrals that I want to take back to a single wire per lug to conform to NEC 408.41 Grounded Conductor Terminations.
Silver
I have 5 open lugs on my ground bar, 2 on the top and 3 at the bottom.
Electrical cable Wire
Can I put the 5 double-tapped neutrals on the ground bar or is that not permitted by NEC 200.2 (B) Continuity ?
If not permitted, what to do ?
Thanks so much.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
