Dennis Alwon said:
This is true. A transfer switch is a double pole double throw disconnect. I also have never seen a Doble throw breaker.
Double throw means it will energize something in one position and something else in the other position. There are also DP Double throw switches with a center off position.
Double-throw simply means you are providing two paths for the current to flow. You can either use them as a transfer switch, giving you the option to 'choose' between two sources of power, or you can apply one source of power to the common terminal and 'choose' which load to send it to.
The number of poles is roughly dependant on the number of power sources (2 or single-phase, 3 for 3-phase, etc.)
