jeff48356
- Livonia, Michigan
Is there any Code that prohibits downgrading the main breaker size in a 200A panel to 150A? Let's say I buy an old run-down house, demolish it, and build a new house in its place. The neighborhood uses overhead service drops only good for 150 amps. However, I want a panel with 40 spaces in it, which only comes in 200A. Could I install 150A service, change the main breaker to a 150A, and then use the panel as a 150-amp panel?
