Downlights with Housing or Housing-free
designer82
Boston
I am selecting some downlights for an 8 unit multi-family residential and I can't figure out whether 6" downlights with housing or housing-free are more appropriate. Any help?
Thanks
It's mostly a preference. I like the housing-free because you can get the spacing much more accurate for your lay-out. Just wait till the ceiling is finished and cut in the lights where you want. Of course some preplaning is necessary to know where to leave the wire for each light. Just leave extra wire to leave room for adjustment.
I personally don't like to use the housing free ones to me I feel like it's more work,labor going back to cut out all the lights . Plus it's messy I hate drilling holes in sheetrock like that
Sent from my SM-G986U using Tapatalk
Use a "pie pan" type collector on your hole saw. No mess with these. We cut in approx. 70 of these in a new house just last week with zero mess. With the spacing this customer wanted, there was no way to use standard can housings.
I guess in some situations there good, but you don't see it as being double the work?
Normal scenario you nail in a can, wire it, come.back later put bulb and trim
Canless you pull the wire , measure out comeback drill hole wire it .
I don't see it as double work.
Both cases you have to pull wire
Both cases you have to wire it
One case you measure and nail up a housing
One case you measure and leave the wire
Maybe a small amount of extra work, such as measuring where to leave the wire, then measure to cut the hole.
Then again, you don't have to both put in the trim and screw in a bulb. So all-in-all, maybe a tiny bit more work. I will admit that I rather use the canless for old work more than for new.
Disclaimer: I actually hate all can light installs!!!
Haa ha lol. Agreed for remodels canless all day I prefer cans in new condition , also with the canless you can't get any lightning on the job until rock is up
I have a friend with a lot of rental properties. The market is hot, so he did some remodeling on a couple and sold them. He asked me to come by and help with a couple of items. One being recessed lighting. He told me he bought LED trims that don’t require a can, but can’t get them to stay in the hole.
Luckily he saved the housing and I was able to properly repair it. I told him to please call me next time before attempting electrical repairs.
For me it’s can lights, I think it looks a lot more professional, also seams like more options, trims, bulbs, etc. installed some housing-less, thought I was a cool idea and system, but really did not look good, maybe because it was wavy sheetrock.
I do not see it as more or less work at all, remodel or not.
“ shoot low boys their riding shetland ponies”
I have used lots of can killers the last 3-4 years, however i have changed my mind and will no longer recommend them. One of the primary reasons is the lack of serviceability. Joe homeowner can change a bulb but probably not replace a can killer.
The other big reason is buzzing and dimming issues. I'm just so sick of it. The Lithonias I have been using (which I used because I assumed they would be better than many if these no name ones) make a noticable buzz. It would drive me crazy. Another brand I used flickers briefly occasionally. I'm done. With A base led bulbs at least you can just try another brand if you are having issues.
I agree with above post AND my concern is exact replacements in the future. What happens when one goes out. Will you find the exact color temp / CRI AFTER the others have aged? Will it be the same style trim? There are SO many brands and one offs that I cant help but wonder what the life expectancy will be. With a traditional can, I know I can replace all will screw in LEDs, incandescent, OR retro LED trims. Totally flexible for future replacement. The only drawback is slightly less install flexibility but I am ok with that.
I care less if its in a pantry, closet or other one off utility area, but for a bedroom, Livingroom, kit etc... I use cans when I can, pun intended.
I Agree cans for me all the way
