Drain of the electrical pvc pipe
Marknewjersey
USA New Jersey
The inspector told me we have to drain the pvc pipe 3/4 that was ran outside.. But what's the way to drain a pvc pipe... Any ideas plz..
Plus what is the "FST Proof Seal"
He told me since you are running a wire from inside to outside then you will have to put that seal too..
I always run outdoor pipes without draining and the other inspectors pass it..
He gave me these articles
225. 22
314. 15
300. 7
Plz help thank u
As long as the conductors inside the pipe are rated for wet areas (or direct burial), water in the PVC conduit is not a problem. It is generally considered to unavoidable and not a code concern.
If water from the conduit could drip inside electrical equipment that could be a code concern.
And if the water enters a "dry" space and causes problems, that is a design concern, not code issue.
