I connect Dranetz PX5 meters to monitor customer power usage from time to time and I am confused on the connection for a 3 wire Wye connection without a neutral.
When I have a neutral available and used, I connect the amp probe and the neutral voltage connection as in the page 3 Phase 4 Wire Wye. This page does not show the neutral amp probe, but I connect it when the neutral is used.
Some times there is a neutral available but it is not being used by the load being monitored so I make the connection as shown on the page 3 Phase 4 Wire Wye.
My question is, When I have a 3 Phase Wye system that does not have the neutral available, how should I connect the meter.
There is a drawing for a 3 Phase (Floating or Grounded) Delta system.
Is this how I should connect the meter or should I connect it like the 3 Phase 4 Wire Wye and connect the neutral and ground voltage probes to ground?
