Zane Bailey
Where in the code (250) does it require bonding/grounding connections to be drilled and tapped? Also where is indicated in (250) that a ground screw must be green?
It is my understanding that a ground screw cannot be a sheetmetal screw It however can be a sheetrock screw as far as I know.Zane Bailey said:Where in the code (250) does it require bonding/grounding connections to be drilled and tapped? Also where is indicated in (250) that a ground screw must be green?
First Q...Zane Bailey said:Where in the code (250) does it require bonding/grounding connections to be drilled and tapped? Also where is indicated in (250) that a ground screw must be green?
2008 NEC
250.8 Connection of Grounding and Bonding
Equipment.
(A) Permitted Methods. Grounding conductors and bonding jumpers shall be connected by one of the following means:
(1) Listed pressure connectors(B) Methods Not Permitted. Connection devices or fittings that depend solely on solder shall not be used.
(2) Terminal bars
(3) Pressure connectors listed as grounding and bonding equipment
(4) Exothermic welding process
(5) Machine screw-type fasteners that engage not less than two threads or are secured with a nut
(6) Thread-forming machine screws that engage not less than two threads in the enclosure
(7) Connections that are part of a listed assembly
(8) Other listed means
quogueelectric said:....It however can be a sheetrock screw as far as I know.
Zane Bailey said:Also where is indicated in (250) that a ground screw must be green?
iwire said:The only 'ground screw' that is NEC required to be green is the grounding screw on a wiring device like a switch, receptacle, cord cap etc.
See 250.126 for that requirement.
There is no requirement that the screw used to attach an EGC to an enclosure be green.
quogueelectric said:It however can be a sheetrock screw as far as I know.
frizbeedog said:250.8.....if 2008 (changes this cycle) Lists the permitted methods.
No mention of green......Myth?
10-32 macine screw for me. The green screws you buy will be a 10-32
I drill and tap the hole with a combo drill tap bit.
