Drill bit size?
7/8 hole in the center of a 3 1/2 stud will have a 1/16 larger required distance to wire so no nail plate
The way I see it is the stud is 3 1/2 inches. 1 inch hole is compliant. Because you will still have 1 1/4 from each face. Am I wrong here. (Edited for spelling)
No. The extra margin allows for less than perfect centering and/or perpendicular drilling.
I use 3/4" also, need more than that then drill two holes. For a single 14/2 for something like lighting might even go with 1/2".
Code knowledge in this rural area is rare and 1" + bits are commonplace. A wise investment is in nail plate stock.......
You are correct, so long as you drill 100% center of the stud and 100% straight going through.
As @LarryFine said, the smaller bit allows for imperfect drilling
I too, use several sizes. You can drill holes fast with a half inch paddle bit in a 120 volt high speed drill.
On custom homes. I treat the studs as if it were my own home. Therefore I keep the holes as minimal as possible.
But on apartments , yes likely the 7/8s stays in the big drills
I like to do less work, A 1" hole removes 4X the amount of wood that is required for a 1/2" hole. A 3/4" hole removes more than twice the amount of wood required for a 1/2" hole. For me the smaller the hole the better. :)
I drill out using 2-18v hammer drills, so smaller is better up to a point.
I use the Diablo/Bosch spade bits with the corkscrew on the tip. I have a 6" bit in one drill, and a 6" bit + 12" extension in the other drill. The coupler on the extension is 5/8" diameter, so I need a hole bigger than that.
I just use a 3/4" for almost everything and then I have consistent hole sizes
