jeff48356
- Livonia, Michigan
I will be wiring a new house being built with Truss Joists (wooden I-beam type joists). Am I allowed to drill holes through the particle-board part of them for running Romex through? No hole will be larger than 1-1/8". I realize most of them have pre-fabbed knockouts that you can remove with a hammer, but often they are not all lined up straight with each other, making cable difficult to pull. I would rather drill the holes than use the knockouts.
