Davebones
- North Of Tampa Fl
Can you drill metal I-beams ,bar joist's in a manufacturing plant to hang box's ,strap's etc .... Is there a code on this ?
I hear people say it will weaken the structure .All the time I've been in the trade we were allowed unless it had a fireproofing sprayed on it . Our carpenter at work is questioning this . I wanted to see what other people had to say ...
carpenter? Are you talking about drilling engineered I joists (wood), or steel I beams?
Attention to the OP might help.. don't know... I've drilled (seems like a lot of work) beam clamped and stuck threaded rod between the joists, Tech5, shot a cap. Seems more like what the job spec's will let you do, as opposed to what one would like to do.
we use a stud gun to weld a internal threaded stud to a beam. You can then mount a box or attach all thread.
Our facility has columns & you cannot wield or drill them. Only clamps are allowed. Wielding will make them brittle & drilling holes weakens them, or so say the wise. We also have four 15 ton crains rolling across the top of ours.
In the past I have seen everything including EMT wielded to them.
Not any more.
I simply ask the customer to have a structural engineer or Architect approve what we intend to do and after this we're covered.
Roger
