kurt.brinker
I've got a dry style transformer with the weathershields installed. Is there any reason this can't be installed outside? Any downside to it?
tom baker said:A Sd D indoor transformer can be used outdoors with the correct mfgs weathershield. As was pointed out, check the instructions.
kurt.brinker said:I've got a dry style transformer with the weathershields installed. Is there any reason this can't be installed outside? Any downside to it?
shwazqrt said:BUT,, ANYWAY GUYZ ... i thought that dry type XFMR is only inside, does not it ?
iwire said:No, 'dry type' transformers can be used outdoors providing you buy the rain shield. Normally the rain shield part number can be found on the label.
That said I do agree with Laszlo that even if it can be done it may not be the best design.
weressl said:Potted transformers are also dry type transformers and they are built specifically for outdoor, severe environments.
kurt.brinker said:this is the one i bought.
http://www.grainger.com/Grainger/items/1TBP6
HighWirey said:It seems that every 'off-the-shelf' piece of electrical equipment intended to be exposed to the elements needs to have an additional coat of whatever corrosion control product (paint) is in vogue in your area. All steel rusts out quickly without some help.
Rhetorical question: Maybe that is an ECs 'planned obsolence'. Everyone else hazzit. I personally liked all of my installs to last forever.
Best Wishes Everyone
