Dry-type transformer grounding
What is the correct size of the grounding electrode conductor for a 30KVA, 480v-120/208v, 3ph, 4wire dry type transformer that supplies 120/208v power to a building distribution panelboard with a 100A, MCB? Is the grounding electrode conductor be sized per Table 250-66 or Table 250-122? The 1999 NEC code no longer classifies step down transformers as separately derived system. Is this true?
Re: Dry-type transformer grounding
Step downs are still considered SDS.
The GEC is based on the size of the secondary conductors size from table 250.66
You need both. The grounding electrode conductor for the secondary is based on 250.66 and a equipment grounding conductor base on 250.122
based on the primary OC device.
