Re: Dry -vs- Oil Filled Transformers
Oil-filled Pros:
Quieter, can be loaded heavier (more efficient cooling), can withstand higher SC currents (typically), weather & atmosphere immune, can have a higher BIL -vs- dry.
Oil-filled cons.
Oil spill near marina bad, heavier, requires periodic tests of oil, more expensive, may require oil containment, oil is fire hazard, bio-degradable or high-flash oils more expensive.
Dry can be purchased as "encapsulated" (not as good if you are going to "Push" them KVA wise)
or with special VPI varnishes for severe duty.
Either will work if specs are correct.
