I just wanted to verify with someone the correct wire gauge for a dryer circuit. From what I see, the wire should be 10-3 on a 30 amp double pole breaker. But, when I looked at my old dryer circuit that has been in the house since it was built in 1980, the wire gauge is significantly larger and the legth is only about 10 feet total from breaker to receptacle. I've seen this in several other houses as well. I just wanted to confirm since I'm moving the dryer upstairs and the wire length will be about 50 feet. Thanks!
