Hello,
I just purchased a new dryer and connected 4 wire as follow, see pic:
dryer connection
Well I plugged it in and it did not start. Problem is I am no electrician and have no clue, just tried following the steps as directed. My old dryer had the white wire hanging loose with the black,green (middle), and red connected. The new connection was not the same, the middle wire of the dryer connection is white with yellow, so I screwed the white wire from the plug with the middle yellow and white. The green wire I screwed with green ground screw. Is this wrong? Should the green be with the white and yellow wires of the dryer? Thanks for your help in advance! rebpan
dryer connection
