Dryer plug, 4 prong.
It looks like you'll need to rewire the circuit with #10-3 Romex cable. And if it was built in 1996, I'm surprised it doesn't already have 4-wire, since the requirement for 4-wire ranges and dryers went into effect in 1994.
Not every structure built was wired to the 'current' code of the day. Some AHJs are 10-20 years behind in code cycles. If there was any code being enforced at all at the time.
And it's not always the NEC. Threre's plenty of home-grown codes to go around.
While the best option is a new 4-wire circuit, the existing is code compliant so another option is convert the dryer to 3-wire, I did not read most of the other posts, never really liked 3-wire receptacles, but they are still OK as existing.
