I just discovered, after tracing the 10/3 cable from a three-prong dryer receptacle that it connected to a non-grounding 3-conductor cable in a J box. That cable runs to the main panel. I have several questions, but I understand that code requirements changed at some point in the 1990s, and a regular copper element was then required for grounding, separating the ground function from the neutral conductor.
My question is,
1) if I'm extending the cable run, is it okay to just use 10/3 cable and not use the ground wire? 2) Would it be a good idea to add a separate copper wire from the panel to the outlet, if I rewired the cable at the panel, putting the neutral wire on the neutral bar?
3) Or should I just leave things as they are?
The reason I haven't mentioned running a new cable from the panel, rather than the J box, is that the home run is behind sheetrock, and not easily accessed.
Thanks!
My question is,
Thanks!
