pipe_bender
- Boston
- Electrician
Here is a mystery for the gang;
Installed some GFCI's in a basement laundry room in a older apartment building one dryer is gas the other is electric.
Got a call that now whenever a dryer runs the GFCI for the washer next to it trips.
Each washer was on its own breaker I did not do anything to the dryers.
It even happens if the washer is not running, these are commercial coin operated units.
The lighting is on a different circuit and got converted to LED around the same time, nothing else changed.
Panel is older SQD QO.
Any ideas what the issue is?
Thanks
Thanks
