Certainly the code making panel had good reason to insist that three-wire cable be replaced with four-wire cable (the fourth wire being the equipment ground wire) for ranges and dryers, but have you had any instances where a three wire cable supplying a range or dryer provided shocks due to lack of an equipment ground wire?
Both my range and dryer are three-wire without ground and I've had none.
Thanks
Thanks
