Spray with what?I’m currently working on a residential basement renovation.
The ceiling ( joist space) is going to have dryfall finish applied.
Is it allowable to spray the recessed can housings?
What about the NM cable as well?
Thanks
The OP said Dryfall which is paint that drys quickly. It generally used on very high ceilings so minimal protection of the area below is needed. The paint drys as it falls so its basically dust that can be swept up.Spray with what?
Ron
Dryfall! Ok. This is new to me. Thank you, sir!The OP said Dryfall which is paint that drys quickly. It generally used on very high ceilings so minimal protection of the area below is needed. The paint drys as it falls so its basically dust that can be swept up.
Not sure why this would ever be used on a dwelling basement ceiling.
I thought it was a typo. (Drywall)Dryfall! Ok. This is new to me. Thank you, sir!
Ron
With a ceiling height of less than 8' I can't see the purpose. The overspray is supposed to dry on its way down before it hits the floor but that's with a 20-25' high working height. Just use regular paint and an airless paint rig. Gonna be the same thing.Not sure why this would ever be used on a dwelling basement ceiling.
