I was at a home today looking at another contractors work and saw that they used "dual coax" to every tv location. why would you need two coax's?
RH and LH channel RF spectrum require dual signal distribution having separate interface for channel range selection.
Most likely because he got it on Ebay cheap and he has no idea what he is doing.
-Hal
Or it is so some HDTV satellite systems can have two tuners active on a DVR. I am not a pro in this area, but I know DirectTV requires this on some of their systems.
Translation:RH and LH channel RF spectrum require dual signal distribution having separate interface for channel range selection.
Translation:
Satellite TV tuners, like DirecTV's for example, uses two lines to each tuner, which enables dual-tuner use. Some channels use right-hand circular polarization, and some use left-hand, which effectively allows two channels for each frequency.
Either of two DC voltages (12-13v or 17-18v) is superimposed on each line from each receiver to the multi-switch (or directly to the dish with only one dual-tuner) to determine which polarization your chosen channel's signal is coming from.
Not after reading the other posts.So then if new installations is it a good idea to run a dual coax and a cat5e homerun to each location?
When I lived in Springfield, Va, (Fairfax Co., DC suburb), the cable company used two 60-channel cables, aka A & B, one of which also carried stereo music channels and Stereo FM simulcast of the movie channels, giving (analog) Dolby Surround with a surround decoder (which, of course, I had.)For years some local cable companies around here required dual coax as the cable boxes had "A&B" inputs so they could provide more services.
I have run into many satellite dual tuners that require 2 input lines to the tuner and an additional line to be run out to a remote TV that is tuned by a RF remote control where the local tv is tuned by an IR remote control. . . . .
good point; i didn't even think about that one.
but i have seen some of the newer receivers not require this for the TV2 output.
they now install a diplexer before the switch, and run the modulated output back to the diplexer. So basically they're running three separate lines @ the receiver back to one. They install a another diplexer/combiner where all the coax lines come out and use it to split off to another room.
I seem to recall, perhaps ten years back .... wasn't everyone excited about a 'new' cable then, for structured wiring systems, that supplied every plate with two coax and four Cat-5 cables?
