Home is a fully-gutted remodel, all old wiring removed, 2 new 200a panels installed indoors. First time using an ATS -- When Gen power is active, gen has 60a breaker and the next disconnect breaker in line is the 200a in panel 1. Can the neutral case ground bond occur in panel 1 with the neutral and ground bar in ATS remaining isolated? Customer wants all metal conduit and fittings, but I believe the ATS to panel 2 must include PVC at some point as to not maintain a conducting path. The meter is yet-to-be-supplied by the utility, and am waiting on clarity for what exactly they're providing. NEC 2014 applies. Previous 2 panel install used 2 outdoor disconnects, one to each panel with each outdoor disconnect bonded. They were connected separately to single meter via PVC. As of yet no outdoor equipment mounted.
