Hi, I'm in the process of building a new home. I want to build an attached garage this fall and the main house next spring. The meter base(400A) will be attached to the garage on the common wall with the house. I would like to place one 200A panelboards inside the garage within 6 feet or so of the meter base. The other 200A panel I would like to place in the basement of the house approximately 20' from the meter base. The power company feeds are underground. I plan to run 3" PVC from the meter base to both panelboards. The conduit for the long 20' run will be frimly attached to the exterior of the basement foundation. The panelboard will be connected at the point the conduit enters the basement. My question is: Does this meet the code requirements? I've read NEC 230. I believe it is leagl but I don't understand what grouping of disconnects means. Am I required to put a 200A fused disconnect inside the garage next to the first 200 panelboard to feed the second panel in the basement? Thanks in Advace, Mac.
