Jerseydaze
What kind of 3 pole switch should I use for the inside unit of a ductless split system ? Will be installed in finished home on wall .
You can get a 3 pole toggle but what I prefer to do is to run my power to a standard dp switch near the unit and then go from there to the outside disco.What kind of 3 pole switch should I use for the inside unit of a ductless split system ? Will be installed in finished home on wall .
I have never seen a separate disco installed or even required for the inside unit.
-Hal
