Duplex meter pan
Jerseydaze
Duplex meter pan Im looking for a residential duplex meter pan with 2 built in 100 amp mains for an over head service does anyone know if such thing exists.
Check with your local supply house. They will usually stock what is "allowed" by the POCO in your area.
In the end the POCO has to approve which meter box is accepted.
Call the POCO...they will determine what is allowed.
As far as checking with supply houses(SH)...good luck...Cooper only carries Sq.D - if the POCO doesn't allow Sq.D ....keep driving until you hit the next SH....
...on the other hand, the POCO might only accept Sq.D.
