volt101
- New Hampshire
Got a call today asking "How many panels would the code require for a duplex w/ some common loads(well, septic pump, common furnace, and common lights for a common room)". The 2002 code section 210.25 tells us that the branch circuits for a dwelling must only supply loads to that dwelling. So can branch circuits that are "dedicated to there respective dwelling derive from a common panel? The "House panel" is understood that it is required. But what equipment would you consider the code is referencing? Could the disconnect that supplies the "House panel" as well as the tenet panel be considered?
