K8MHZ
- Electrician
A friend of mine, not an electrician, had a cheapie DVOM and he heard something rattle inside it. He took it apart (he is a ham radio operator, we have a bad habit of fixing our own stuff...) and found nothing loose. Re-assembled and no more rattle. A short time later, pun intended, he was checking for voltage in a residence. He checked the 240 legs ahead of the main and when he did the meter shorted out and exploded, vaporizing the test leads and covering my friend's arm and hand with burnt plastic.
We had a little talk about PPE and a workable minimum for what he pokes around in.
However, the gist of the story is the arc flash hazard present even when doing something as routine as checking for voltage in a house panel.
My friend didn't save the meter for me to look at. If so, I would have had some pics for you. So solly.
