Dwelling Hood-Fan Requirement
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Is there a code requirement (electrical, mechanical, other) that states a hood fan is to be installed over a dwelling unit range?
Thank you.
growler
Atlanta,GA
Thank you.
There could be a local code. From what I can see ASHRAE has developed a standard that would require some sort of ventilation.
I did a quick search and found a Home Inspector looking for a reason to write it up as a concern and their standard would be good enough for that purpose.
rcarroll
'06 IRC M1901.1
Freestanding or built-in ranges shall have a vertical clearance above the cooking top of not less than 30" to unprotected combustible material. Reduced clearances are permitted in accordance with the listing & labeling of the range hoods or appliances.
Hope this helps.
electricmanscott
Boston, MA
'06 IRC M1901.1
Hope this helps.
What does this have to do with whether or not ventialtion is required? :confused:
