Kessler4130
- Maryland
As title says, a customer is converting a single family dwelling into a car lot, being zoned c4 I believe I can still use romex and I do not know of any local ammendments saying otherwise. However, now the building being reclassified, none of the dwelling requirements for branch circuits should apply, but what about fire alarm ? Is it required to be a monitored system of some sort, do I need pull stations now that it has been re-zoned ? There aren't really engineered drawings, the only drawing they have does show one exit/emergency light by the front door but none at the back door which I am pretty sure is required if the door can be used as an egress. I will probably have to contact the local fire marshall to be sure but figured I would give it a shot here first.
