Deka
- California, USA
- Electrical Instructor
Hi guys,
I'm here looking at my 2017 NEC,
Recently I've seen, on more than one Electrician Chat sites,
that, in a residential setting, a 24 inch or greater wall space requires a receptacle.
At NEC 210.52(a)1 states "Receptacles shall be installled such that no point measured horizontally along the floor line of any wall space is more than
6 ft. from a receptacle."
at 210.52(a)2 states "As used in this setion, a wall space shall inclued the following:"
"1. Any space ...2ft or more in width, including space measured around corners, and unbroken along the floor line by doorways and similar openings, fireplaces, and fixed cabinets that do not have countertops or similar work surfaces."
So to my understanding, the 2 ft. mentioned here, qualifies as "Wall Space." Nothing in this section of code states that a receptacle is required for a 2 ft. section.
In contrast, referring to countertops, 210.52(c)1 states "A receptacle outlet SHALL BE INSTALLED at each wall countertop and work surface that is 12 in. or wider.
A receptacle requirement is specifically mentioned for a 12 in. or wider countertop.
So, is there another code reference in the NEC that requires a receptacle, in a dwelling, for a 2 foot wall space?
And if not, does anyone know the source of this 2 ft. rule?
Thank you.
Thank you.
