Does anyone know if there is an off-the-shelf chopper (braking module) that would connect to AC line? There is an application where large DC drives running DC motors are connected to 600V generators. These motors can have significant reverse power at times and manufacturer of DC drives has confirmed the drive can regen the power back to line but the problem is this obviously can damage the generators. DC drive manufacturer does not have any solution because they say their drives are usually used on utility where reverse power is not a problem.
Does anyone know of an off-the-shelf "AC" chopper with built-in power transducer that can sense the reverse power and turn on braking resistors? Or, maybe a stupid question, is it possible to connect regular choppers (with DC input) to the motor leads (aka, in parallel with DC drives)?
We already have a solution which is a combination of a rectifier, PLC, power transducer and resistor bank along with some current transformers. PLC monitors the power flow and turns on the rectifier on resistors to dissipate the power but this requires engineering and product support.
