Electriman
- TX
Greetings,
I have a 2.4 kv motors that I am protecting it via a 12R fuse. The fuse is fed using a 2/0 cable from upstream. So to protect the cable I have to use a 200E rated fuse. But the problem I have 200E fuse is not coordinated with 12R rated fuse and it does not allow the motor to start. Do you have any recommendation?
